Jeep engine performance including horsepower mods and V8 engine swaps - Jeep at Off-Road.com
Jeep »
Price and Compare Vehicles:
New, Used, and Powersports    Go button
Tech: Performance
Off-Road Jeep engine parts that increase horsepower, intakes, exhaust, carburetor, fuel injection, power chips, ignition system, spark plugs, headers, pistons, pulleys, power module for your Jeep Cherokee, Wrangler, CJ, TJ, YJ, JK & ZJ from Banks Power, Super Chips, AFE, Voltair, K&N.
The Jeep Creep Answers Your Questions
Jun 17, 2009
The Jeep Creep answers questions about catalytic converters, superchargers, Jeep brake light trouble and a Jeep's overdrive.
AMC 360 V-8 Easy Ignition Upgrade
Aug 20, 2008
Our tired AMC 360 V-8 gets new life with a simple and easy ignition upgrade. It is cheap, effective and almost anyone can do it. Read on for the details.
The Jeep Creep Answers Questions About Squealing, Squeaking and Leaking Jeeps
Aug 6, 2008
In this installment the Jeep Creep answers your technical questions about the Jeep YJ and TJ. Everything from a Jeeps that squeak to Jeeps that leak is covered here.
Weekend Warrior: Part III - Volant Performance CAI and PeriScoop
Adding more breathing power to your Jeep
Oct 22, 2007
The Jeep Rubicon 4.0 liter engine could use better breathing habits--adding more horsepower and torque. I wanted a simple bolt on system that I could perform myself in my garage. I turned to Daniel at Volant Performance for our engine aspiration needs. Volant Performance has a three part modular system that can be done in stages or all at once.
Demystifying the Delco SI Alternator, Part I
Nov 1, 2006
The entire charge of your vehicle, every electron used by every system in your vehicle is produced by the alternator. Some people will argue this fact, but every electron the battery expends has to be replaced by the alternator.
SHIFT TOWER BOOT for T18 TRANSMISSION
Keeping Water Out of Your T18
Jul 1, 2006
Part III - The V8 Option - Chevy V-8 Swap into a Jeep CJ (or YJ)
May 1, 2006
If you're reading this, you are probably considering swapping a V8 into your Jeep CJ or YJ. I'm lumping the CJ and YJ together because they are so similar. I did my swap in a CJ7, but most of the information will apply to a CJ5 (Post 1976) or a YJ (1987-1996).
Part II - Chevy V-8 Swap into a Jeep CJ (or YJ)
Preparing to install the V8, Part 2 of 3
Apr 1, 2006
In the last installment, I prepped the V8 for installation and talked about researching your options. This section deals with diving right in and removing your old engine and everything up to dropping in the new engine
Part II - Chevy V-8 Swap into a Jeep CJ (or YJ) - Page 2
Apr 1, 2006
Jeep CJ and YJ radiators have the lower and upper hoses on the wrong side of the engine for a Chevy V8. In addition, the stock 2 core radiator, or an older radiator, will simply not cool enough for your new V8
Untitled Document
HOLY CRAP Or Your Money Back -
Once you try it - we dare you to drive without it. To learn more click here.
Off-Road Videos -
ATV Reviews -
Own your very own Off Road Superstore.....
How many times have you pondered the idea of owning your very own off road shop? Let the staff at Off Road Innovations, one of the largest aftermarket off road accessory dealers in the US, help turn your hobby into a profitable career. Go to www.offroadinc.net for more info or just call 800-809-6088.
MSD Ignition Rebate!
Fire up with MSD Ignition and receive Cash for Cruising! Click on the link to find out the latest cash back rebate from MSD.
Enewsletters
Stay on Top of All the Action:
Sign up for Off-Road.com's Enewsletters
You'll need to upgrade your Flash Player to view the GoodYear Tire Search
Click here
