Jeep transmissions, axles, lockers, gears, transfer case, drive lines and other key drivetrain components for your 4x4 - Jeep at Off-Road.com
Jeep »
Price and Compare Vehicles:
New, Used, and Powersports    Go button
Tech: Drivetrain
Off-Road drivetrain articles and tech showing you how to repair and upgrade your transmission, transfer case, drivelines, axles, gears and other key drivetrain components on your Jeep Cherokee, Wrangler, CJ, TJ, YJ, JK & ZJ. Reviews on ARB, Yukon, Eaton, Poly Performance, Terra-flex.
The Dana 44 Grease Nipple Mod
Oct 31, 2008
Greasing the wheel bearings on a semi-floating rear Dana 44 can be an almost impossible task. Even after taking apart half the axle, it is still hard to get the bearings the proper amount of grease. This modification makes greasing the bearings a breeze. Check it out.
The STaK 4x4 Mini Monster Transfer Case
Sep 23, 2008
The original Monster Box was big, beefy and the first-three speed transfer case available. Now STak 4x4 introduces the Mini Monster. With smaller dimensions it easily fits in the frame rail of almost any Jeep, 4x4 or truck adding much needed gear reduction and strength. We take a peek inside the monster to see what makes it so stout.
Tom Woods Custom Jeep JK Drive Shafts - Review
Eliminating The Weak Link
Oct 15, 2007
By now, most Jeep JK owners have taken a peek under their rigs, only to find drive shafts that are totally unusable.
Waterproofing A Dana 44 Front Hub
Dana 44 Front Hub Grease Nipple Installation
Jul 15, 2006
The internal-spline Dana 44 front hub uses two tapered roller bearings, and a seal at the inboard end of the hub. At the outboard end of the hub is a drive-in cap that can allow water to enter, bringing grit along with it. Adding to the problem is the large volume of air in the hub.
Using CO2 For Your Locker
Use a CO2 tank to operate your ARB locking differentials!
May 1, 2006
By a huge margin, the number one question I get asked when people see my Jeep for the first time is: ?what is that tank in the back?? The tank is, of course a compressed liquid CO2 tank. But it can be used for so much more than just filling your tires. Read on??
IH Dana 300
Nov 1, 2005
The Dana 300 transfer case used in 1980 IH Scout IIs uses the same bolt pattern and input hole size as the Jeep Dana 20. It is a great transfer case to use as an upgrade to the Jeep Dana 20 because it has a much better low range. It is a gear drivin transfer case with a cast iron case. Low range is 2.62:1.
Jeep Transmissions Conversions
Nov 1, 2005
The SM465 is the replacement for the SM420.
Ford T-18
Nov 1, 2005
The Ford version of the T-18 was used approximately from 1967 until 1984. It is a heavy duty four speed manual transmission that is available in wide and close ratio, but I've only seen the wide ratio version in Ford trucks. The transmission weighs close to 150 pounds.
Swapping an Early Bronco Front Dana 44 into a YJ
Nov 1, 2005
There are many advantages to swapping an early Bronco Dana 44 into the front of a Wrangler YJ. The Dana 44 has larger u-joints, bigger ring and pinion, larger axle shafts (30 spline), beefy internal hubs, 5 on 5.5" wheel bolt pattern, and good pinion placement.
Untitled Document
HOLY CRAP Or Your Money Back -
Once you try it - we dare you to drive without it. To learn more click here.
Off-Road Videos -
ATV Reviews -
Own your very own Off Road Superstore.....
How many times have you pondered the idea of owning your very own off road shop? Let the staff at Off Road Innovations, one of the largest aftermarket off road accessory dealers in the US, help turn your hobby into a profitable career. Go to www.offroadinc.net for more info or just call 800-809-6088.
MSD Ignition Rebate!
Fire up with MSD Ignition and receive Cash for Cruising! Click on the link to find out the latest cash back rebate from MSD.
Enewsletters
Stay on Top of All the Action:
Sign up for Off-Road.com's Enewsletters
You'll need to upgrade your Flash Player to view the GoodYear Tire Search
Click here
